2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the distance value from the advanced query.
Gets the distance rule starting point from the advanced query.
Sets the distance value to the advanced query.
Sets the distance rule starting point to the advanced query.
Use the Task Manager to load an XML file that defines tasks and their attributes.
