2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the entity set information of the cross section for a given entity type.
Gets the cross section ID.
Gets the IType value of the cross section.
Gets the ITypeID value of the cross section.
Gets the cross section label.
Gets the type of cross section.
Gets the cross section visibility state.
Sets the cross section visibility.
Use the Task Manager to load an XML file that defines tasks and their attributes.
