poIImagePlane GetFilterMode
Gets the current image post-processing filter mode for the image plane.
Imageplane_handle GetFilterMode
HyperView Tcl Query
The image plane offers several image post-processing filters that can be applied on the image or video. Each filter type may have one or more modes. This command returns the active post-processing filter mode for the image plane.
To create one image plane, and then query it for available filter types and
        modes:
    hwi OpenStack
if {[catch {
    hwi GetActiveClientHandle client_handle
    client_handle GetImagePlaneCtrlHandle ipc_handle
    set ipid1 [ipc_handle AddImagePlane Logo1]
    ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
    imageplane_handle SetFileName g:/samples2/VideoOverlay/Altair_logo.jpg
    imageplane_handle SetMode background
    imageplane_handle SetCrop 0 0 0.9995 0.995
    imageplane_handle SetFilterType Edge;
    imageplane_handle SetFilterMode Sobel;
    imageplane_handle SetEdgeColor "255 255 255";
    imageplane_handle SetMipMapMode Linear1
    puts "  Filter Type: [imageplane_handle GetFilterType]";
    puts "  Filter Mode: [imageplane_handle GetFilterMode]";
    puts "  Edge Color:  [imageplane_handle GetEdgeColor]";
    puts "  MipMap Mode: [imageplane_handle GetMipMapMode]";
    client_handle Draw
} result]} {
    global errorInfo;
    puts stderr $result;
    puts "[session_handle GetError]";
    puts stderr "*** Tcl TRACE ***";
    puts stderr $errorInfo;
} else {
    puts "No errors.";
    puts "Warnings: ";
    puts "    [session_handle GetError]";
hwi CloseStackConsole Output:
 Filter Type: Edge
  Filter Mode: Sobel
  Edge Color:  255 255 255
  MipMap Mode: Linear1
No errors.
Warnings:Errors
Returns HW_InvalidHandle if the image plane handle is invalid.
