poIPostManager IsFileSupportedForAsync
Determines whether the given file is supported in HyperView - MultiCore profile.
poIPostManager_handle IsFileSupportedForAsync file_name is_model
HyperView Tcl Query
This command, valid only in HyperView - MultiCore profile, returns true if the given file is supported in HyperView - MultiCore (internally known as Async Mode) and false if it is not supported. Only certain file formats are currently supported in HyperView - MultiCore.
- file_name
- The name of the file.
- is_model
- True if this represents a model file, false otherwise.
To check if a file is supported in HyperView - MultiCore profile:
hwi OpenStack
hwi GetSessionHandle sess
sess GetClientManagerHandle mgr animation
mgr IsFileSupportedForAsync c:/models/d3plot false
hwi CloseStackErrors
None.
Related Topics
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
