poIQueryCtrl SetRemoveDuplicates
Sets the state of the remove duplicates option in the query handle.
poIQueryControl_handle SetRemoveDuplicates state
HyperView Tcl Modify
This command sets the state of the remove duplicates option (which will remove duplicate node data queried when set to True).
- state
- Boolean value to set the remove duplicates state (True/False).
To remove the duplicate node data
        queried:
    hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
set sid [model_handle AddSelectionSet node]
model_handle GetSelectioSetHandle selset_handle $sid
selset_handle Add all
model_handle GetQueryCtrlHandle query_handle
query_handle SetRemoveDuplicates true
query_handle SetQuery "node.id node.coord component.id"
query_handle SetSelectionSet $sid
query_handle GetIteratorHandle iter_handle
for { iter_handle First }  { [iter_handle Valid] } { iter_handle Next } {
      iter_handle GetDataList
hwi CloseStackErrors
Returns an error if the value state cannot be applied.
