poIResultMathCtrl GetTableInfoList
Gets the format and binding information of a table.
rmath_handle GetTableInfoList table_name res_name
HyperView Tcl Query
This command returns the format and binding information of a table. The first item contained in the list is the format of the table (scalar/vector/tensor), and the second item in the list is the binding of the table (node/element/part).
- table_name
- The name of the table whose information is needed.
- res_name (Optional)
- The resource name of the table.
To get the format and binding information of the specified
        table:
    hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set tabinfo_list [rmath_handle GetTableInfoList Stress]
hwi CloseStackErrors
None.
