Create Joint Hubs
Use the Joint Box tool to define junctions in your skeleton model.
From the Skeleton ribbon, click the Joint Box
tool.
図 2.
Select the node or elements around which to create a bounding box.
Any elements found within the box are used for joint creation.
図 3.
Click
on the ガイドバー to define
options.
- Create joint box
- Use the box as a mechanism to select elements to generate the joint location and legs.
- Remove joint legs
- Create a joint without the corresponding legs.
- Mesh member joint
- Automatically create 1D mesh on the joint legs and apply the beam sections.
- Dimensions
Controls the length, width, and weight of the bounding box.
- Use orientation and dimensions
- For repeated operations, the previous box attribute information can be used so that the box can be created the same repeatedly.
Edit the box size in the following ways:
- Click
in the マイクロダイアログ to
move the box globally. - Click
in the マイクロダイアログ to
update the box's dimensions. You can click a face and drag its arrow or
entire a precise value.
図 4.
- Click
If the member joint is being meshed, set the parameters in the マイクロダイアログ drop-down.
This automatically creates 1D mesh on the joint legs and applies the beamsections.
図 5.
- オプション: Click the Exclude selector on the ガイドバー then pick entities to exclude from the joint if required.
ガイドバーで、下記のオプションのいずれか1つをクリックします:
- 適用し、ツールを開いたままにする
- 適用し、ツールを閉じる
– 適用せずにツールを終了する
Assign Beam Sections to Member Joints
Use the Assign tool if a member joint is created without a beam section or the beam section needs to be changed.
From the Skeleton ribbon, Joint Box tool group, click the
Assign tool.
図 6.
- Select the member joint(s).
- Select the beam section to assign.
- 適用し、ツールを開いたままにする
- 適用し、ツールを閉じる
– 適用せずにツールを終了する
