Fillets
Create fillets or chamfers along an edge.
Fillet Edges
Round edges to create fillets with a constant or variable radius.
On the Geometry ribbon, select the
Fillet Edges tool.
The guide panel appears.
Choose a Radius Type:
- Constant: Create fillets with the same radius for every edge.
- Variable: Create fillets with a variable radius at selected points along the edges.
Choose a Continuity type:
- Tangent: Force tangent (G1) continuity along the edge.
- Curvature: Force curvature (G2) continuity along the edge.
Create and modify edge sets:
To Do this Add an edge set - Click the + button and select the edges.Tip: In the microdialog, select Tangent Propagation so that clicking an edge will also select all of its tangent edges.
To select all of the boundary edges of a face, click the face.
- You can adjust the Radius for each edge set.
Delete the current edge set Under Edge Sets, click
. - Click the + button and select the edges.
Create a modify points (Variable radius only):
To Do this Add a point where the radius varies Click along the edge. Delete selected points - Under Points, click
. - Alternatively, in the modeling window, select a radius handle and press Delete.
Modify the point’s position along the edge Enter a value from 0 to 1, where 0 and 1 correspond to the edge’s endpoints and 0.5 corresponds to the mid of the chain. You can also select the radius handle and drag it along the edge. - Under Points, click
Click Apply.
Features are automatically retained and notches are preserved on sheets.
Tip:
- By default, clicking an edge will also select all of its tangent edges.
Deselect Tangent Propagation
in the microdialog to
disable this behavior. - If the fillet radius text box is highlighted red due to an invalid edge selection, press Ctrl+Z to undo or press Ctrl while clicking to deselect the edge. The previously valid selection will reappear.
- Change the default fillet radius in the Preferences.
Chamfer Edges
Create beveled edges.
Chamfer Edges tool.
Select edges to chamfer.
- To select an edge, click the edge.
- To select multiple edges, use box selection or press Ctrl while clicking the edges.
- To select all of the boundary edges of a face, click the face.
Choose from the following options:
- Distance, Angle: Enter a horizontal distance and an angle.
- Distance, Distance: Enter a horizontal distance and a vertical distance.
If you entered an invalid value, the text box is highlighted in red.
Note: The values you enter will be automatically applied to all selected features. -
Select Apply
on the microdialog.
Tip:
disable this behavior. - Reverse the side the distance and angle are measured from by clicking
in the microdialog. - If a distance/angle text box is highlighted red due to an invalid edge selection, press Ctrl+Z to undo or press Ctrl while clicking to deselect the edge. The previously valid selection will reappear.
- Change the default chamfer distance and angle in the Preferences.
Create or Assign a Variable to Parametrize your Model
Create or assign a variable to parametrize your model. Variables can be created from a tool or the tool’s microdialog where f(x) is present.
You can create or assign existing variables via the microdialog or in various tools.
In the tool or the tool’s microdialog, click the f(x)
icon.
Figure 1. Example of a microdialog with a variable field
Figure 2. Example of a tool with a variable field
- In the dropdown menu, select Create Variable to create a new variable based on the type in the text field, or select the name of an existing similar type variable to assign it.
Tip:
- You can also create a variable by entering a new name and expression in the
microdialog’s text field, for example:
Variable1=50 - In addition, you can also create a new variable based on an existing
variable, for example,
Variable2=Variable1*0.5.
Keyboard Shortcuts & Mouse Controls
| To | Do this |
| Select features | Click |
| Append/remove feature selection | Ctrl+click |
| Delete selected feature | Delete+click |
| Delete selected filleted/chamfered face | Delete |
| Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
