Partition
Divide a solid part into design and non-design regions by selecting a hole, pocket, or face to offset.
On the Geometry ribbon, select the
Partition tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
at the lower right corner of the
currently displayed tool. - Click and hold the currently displayed tool.
Holes and pockets are automatically selected and shown in red. - Select
Select faces to partition.
Selected faces are shown in red.
Click a selected (red) feature to execute the partition, or select
Apply
on the microdialog.
Use the microdialog to edit the default offset value. You can edit the offsets
for multiple partitions while in editing mode.
- Use the Reverse Direction
button to change the direction of the
offset. - Change the Thickness and press Enter. If the thickness you entered is invalid, the text box is highlighted in red.
- Right-click to exit the tool.
Note:
- If you apply a partition to a design space, it automatically creates a non-design space.
- For solids, if you enter a thickness of zero, you will get a surface in a new part. For surfaces, if you enter a thickness of zero, those surfaces will be placed into a new part.
- You can edit the Default Offset value in the Preferences.
- Only solids can be partitioned, not surfaces.
Create or Assign a Variable to Parametrize your Model
Create or assign a variable to parametrize your model. Variables can be created from a tool or the tool’s microdialog where f(x) is present.
You can create or assign existing variables via the microdialog or in various tools.
In the tool or the tool’s microdialog, click the f(x)
icon.
Figure 1. Example of a microdialog with a variable field
Figure 2. Example of a tool with a variable field
- In the dropdown menu, select Create Variable to create a new variable based on the type in the text field, or select the name of an existing similar type variable to assign it.
Tip:
- You can also create a variable by entering a new name and expression in the
microdialog’s text field, for example:
Variable1=50 - In addition, you can also create a new variable based on an existing
variable, for example,
Variable2=Variable1*0.5.
Keyboard Shortcuts & Mouse Controls
| To | Do this |
| Select a feature | Click |
| Deselect a feature | Ctrl+click |
| Add to the selection | Ctrl+click |
| Execute the partition | Click a selected (red) feature to preview and edit it. Click again to partition it. |
| Accept the partition and exit | Right-click in editing mode |
| Delete the partition | Delete or Shift+click |
| Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
