/MAT/LAW23 (PLAS_DAMA)
Block Format Keyword This law models an isotropic elastic plastic material and combines Johnson-Cook material model with a generalized damage model. The law is applicable only for solid elements.
/MAT/LAW23/mat_ID/unit_ID or /MAT/PLAS_DAMA/mat_ID/unit_ID
mat_title
ρ i
E ν
a b n ε p m a x σ max ​ 0
c ε ˙ 0 ICC
ε d a m Et
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young's modulus.
(Real)
[ Pa ]
ν Poisson's ratio.
(Real)
a Plasticity yield stress - should be strictly positive.
(Real)
[ Pa ]
b Plasticity hardening parameter.
(Real)
n Plasticity hardening exponent. 3
(Real)
ε p m a x Failure plastic strain.
Default = 1030 (Real)
σ max ​ 0 Plasticity maximum stress.
[ Pa ]
c Strain rate coefficient.
= 0
No strain rate effect.
Default = 0.00 (Real)
ε ˙ 0 Reference strain rate.
If ε ˙ ≤ ε ˙ 0 , no strain rate effect.
(Real)
[ 1 s ]
ICC Strain rate computation flag. 5
= 0 (Default)
Set to 1.
= 1
Strain rate effect on σ max .
= 2
No strain rate effect on σ max .
(Integer)
ε d a m Damage model starts at ε d a m .
Default = 0.15 (Real)
Et Softening damage slope ( − E < E t ≤ 0 ).
[ Pa ]
Example (Aluminum)
#RADIOSS STARTER
/UNIT/1
unit for mat
                   g                  mm                  ms
#-  2. MATERIALS:
/MAT/LAW23/1/1
Alu
#              RHO_I
               .0027
#                  E                  nu
               70000                  .3
#                  a                   b                   n             Eps_max            sig_max0
                 100                   0                   1                  .2                 100
#                  c               EPS_0       ICC
                   0                   0         0
#            EPS_dam                 E_t
                  .1               -2000
#ENDDATA
/END
  1. The damage law is applied to the stress tensor σ i j and damage occurs in tension, compression and shear.
  2. The input is the same as material law (/MAT/LAW22 (DAMA)).
  3. The plasticity hardening exponent n must be less than one.
  4. When ε p reaches ε p m a x , in one integration point, then the solid element is deleted.
  5. ICC is a flag of the strain rate effect on material maximum stress σ max .
    σ = σ y ( 1 + c ln ( ε ˙ ε ˙ o ) ) σ = σ y ( 1 + c ln ( ε ˙ ε ˙ o ) )
    σ max = σ max 0 ( 1 + c ln ( ε ˙ ε ˙ o ) ) σ max = σ max 0
