/MAT/LAW52 (GURSON)
Block Format Keyword This law is based on the Gurson constitutive law, which is used to model visco-elastic-plastic strain rate dependent porous metals.
| /MAT/LAW52/mat_ID/unit_ID or /MAT/GURSON/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | Iflag | Fsmooth | Fcut | Iyield | |||||
| A | B | N | c | p | |||||
| SN | |||||||||
| fI | fN | fc | fF | ||||||
| Tab_ID | XFAC | YFAC | |||||||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| mat_title | Material title. (Character, maximum 100 characters) |
| Initial density. (Real) |
| E | Young's modulus. (Real) |
| Poisson's ratio. (Real) |
| Iflag | Viscoplastic flow flag. 1
(Integer) |
| Fsmooth | Smooth strain rate are computed.
(Integer) |
| Fcut | Cutoff frequency for strain rate
filtering. Default = 1030 (Real) |
| Iyield | Flag for computing the Yield stress.
3
(Integer) |
| A | Yield stress. (Real) |
| B | Hardening
parameter. (Real) |
| N | Hardening exponent. (Real) |
| c | Strain rate coefficient in
Cowper-Symond's law. (Real) |
| p | Strain rate exponent in Cowper-Symond's
law. (Real) |
| , , | Damage material
parameters. (Real) |
| SN | Gaussian standard
deviation. (Real) |
| Nucleated effective plastic
strain. (Real) |
| fI | Initial void volume fraction. 2 (Real) |
| fN | Nucleated void volume
fraction. (Real) |
| fc | Critical void volume fraction at
coalescence. 2 (Real) |
| fF | Critical void volume fraction at ductile
fracture. 2 (Real) |
| Tab_ID | Yield stress table identifier
(stress-strain functions with correspond strain rate). (Integer) |
| XFAC | Scale factor for the first entry
(plastic strain) in function which used for Tab_ID. Default = 1.0 (Real) |
| YFAC | Scale factor for ordinate (Yield stress)
Example (with parameter input)
#RADIOSS STARTER
/UNIT/1
unit for mat
g mm ms
#- 2. MATERIALS:
/MAT/LAW52/1/1
Steel
# RHO_I
.0078
# E NU_12 Iflag Fsmooth Fcut Iyield
200000 .3 0 0 0 0
# A B N c p
200 533 1 802 3.585
# q_1 q_2 q_3 SN EpsN
1.25 1 2.25 .1 .2
# Fi FN Fc FF
.01 .04 .12 .2
#ENDDATA
/END
Example (with function input)
#RADIOSS STARTER
/UNIT/1
unit for mat
g mm ms
#- 2. MATERIALS:
/MAT/LAW52/1/1
Steel
# RHO_I
.0078
200000 .3 0 0 0 1
# A B N c p
200 533 1 802 3.585
1.25 1 2.25 .1 .2
# Fi FN Fc FF
.01 .04 .12 .2
# Tab_ID XFAC YFAC
1000 0 0
/TABLE/1/1000
curve_list with strain rates
2
# function stain rate
10010 1.0e-4
10020 1.0
/FUNCT/10010
plastic strain vs yield stress funct dt=1.0e-4
# plastic strain yield stress
0.0000 200.
1.0000 733.
/FUNCT/10020
0.0000 250.
1.0000 783.
#ENDDATA
/END
- The von
Mises criteria for viscoplastic flow:
If Iflag = 0:
If Iflag = 1:
if
if
Where, is the admissible stress, is the trace[ ] (hydrostatic stress), is the von Mises stress, and , , and are the material parameter for Gurson Law,
is the specific coalescence function.
if
if
with
corresponding to the coalescence function
- The void volume fraction parameters must be entered so that, .
- If one integration point reaches , the element is deleted.
- If the
Iyield flag is not activated
(Iyield=0), the yield
stress is computed using Cowper-Symond's law:
If the Iyield flag is activated (Iyield=1), the yield stress is computed directly from the Yield stress curves (Tab_ID).
- This law is available for shell and solid elements.
- In plot files (/TH/SHEL, /TH/SH3N and /TH/BRICK) or animation files
(/ANIM), the following variables are available:
- USR1: plastic strain
- USR2:
- USR3: admissible stress
- USR4: f
- USR5:
