Bulk Data Entry Controls checking for unconnected parts when the AMSES eigensolver is used.
| Parameter |
Values |
Description |
| CHKUCON |
<PRE,
AMSE, BOTH,
NO>Default =
- The default is NO when the parameter is
not present in the deck.
- If specified in the input deck without a value, then
the value of this parameter is set to
PRE in this case.
- PRE
- The model is checked for unconnected parts in the
pre-processor (during initial model reading) based on
node-to-node connectivity and any unconnected parts
found are written to the
<filename>.PRE.unconneted.cmf
file.
- AMSE
- The model is checked for unconnected parts in the AMSES
eigensolver based on the profile of the K, M, and GE
matrices and any unconnected parts found are written to
the
<filename>.AMSE.unconneted.cmf
file.
- BOTH
- The checks are done at both places mentioned in
PRE and AMSE
options.
- NO
- No checks are done for unconnected parts.
- For more information about AMSES, refer to Solvers in the User
Guide.
