PARAM, SBTOLRTR
Bulk Data Entry Used to modify the tolerance value for symmetric beams when they are used for rotor modeling.
Parameter Values Description
SBTOLRTR <Real > 0.0>
Default = 1.0E-6 if parameter is not present in the model.
The tolerance value ( v a l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamODaiaadg gacaWGSbaaaa@38C9@ ) is used in the following checks:
Relative Tolerance for Bending Stiffness
| E I y y − E I z z | E I y y E I z z ≤ v a l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaada abdaqaaiaadweacaWGjbWaaSbaaSqaaiaadMhacaWG5baabeaakiab gkHiTiaadweacaWGjbWaaSbaaSqaaiaadQhacaWG6baabeaaaOGaay 5bSlaawIa7aaqaamaakaaabaGaamyraiaadMeadaWgaaWcbaGaamyE aiaadMhaaeqaaOGaamyraiaadMeadaWgaaWcbaGaamOEaiaadQhaae qaaaqabaaaaOGaeyizImQaamODaiaadggacaWGSbaaaa@4DD9@
Tolerance for Shear Correction Factor
| k y − k z | ≤ v a l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaqWaaeaaca WGRbWaaSbaaSqaaiaadMhaaeqaaOGaeyOeI0Iaam4AamaaBaaaleaa caWG6baabeaaaOGaay5bSlaawIa7aiabgsMiJkaadAhacaWGHbGaam iBaaaa@42D6@
Tolerance for Neutral Axis Location
| N y | , | N z | ≤ v a l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaqWaaeaaca WGobWaaSbaaSqaaiaadMhaaeqaaaGccaGLhWUaayjcSdGaaiilamaa emaabaGaamOtamaaBaaaleaacaWG6baabeaaaOGaay5bSlaawIa7ai abgsMiJkaadAhacaWGHbGaamiBaaaa@4581@ (at locations A and B)
Tolerance for Offset Vectors
| W 1 | , | W 2 | , | W 3 | ≤ v a l MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaqWaaeaaca WGxbWaaSbaaSqaaiaaigdaaeqaaaGccaGLhWUaayjcSdGaaiilamaa emaabaGaam4vamaaBaaaleaacaaIYaaabeaaaOGaay5bSlaawIa7ai aacYcadaabdaqaaiaadEfadaWgaaWcbaGaaG4maaqabaaakiaawEa7 caGLiWoacqGHKjYOcaWG2bGaamyyaiaadYgaaaa@4AAD@ (at locations A and B)
