PARAM, CONTFEL
Bulk Data Entry Activates contact-friendly elements in Nonlinear Static/Transient Analysis (SMDISP/LGDISP).
Note: This is recommended when second order solids/gaskets are used with contact
analysis in OptiStruct.
| Parameter | Values | Description |
| CONTFEL | <YES, NO, or AUTO> |
- Contact-friendly elements are not required for S2S contact.
- This parameter cannot be specified in the input deck without a value. OptiStruct will error out in this case.
- In Explicit Dynamic Analysis, this parameter is always deactivated, irrespective of the value.
- Contact-friendly elements are only supported and activated in mechanical subcases. For example, they are not effective in heat transfer subcases or electrical subcases.
