PARAM, ERPREFDB
Bulk Data Entry Specifies the reference power value used to calculate Equivalent Radiated Power (ERP) in decibels (dB).
Parameter Values Description
ERPREFDB Real > 0.0
Default = 1.0
The Equivalent Radiated Power (ERP) in decibels can be calculated using the following equation:
ERP dB = 10.0 * log ⁡ 10 ( RHOCP * ERP ERPREFDB )
Where,
E R P d B
Equivalent Radiated Power in decibels.
R H O C P
Value of the scale factor specified using the parameter PARAM, RHOCP.
E R P R E F D B
Reference power value specified using this parameter.
ERP output in dB scale is currently only available in PUNCH format.
