PARAM, NUMEG
Bulk Data Entry Specifies the anticipated number of modes to be calculated in order to estimate disk space usage.
| Parameter | Values | Description |
| NUMEG | <Integer> Default = 1000 |
When ND
on the EIGRL/EIGRA data is
blank, the disk space estimate in the .out file
for modal frequency response and the transient analysis is based on
the number of modes specified by PARAM,
NUMEG. When Lanczos is used, the disk space estimate is based on this value plus the number of the potential residual vectors. When AMLS/AMSES is used, the disk space estimate is based only on the value of PARAM, NUMEG. In this case, it is assumed that PARAM, NUMEG includes the number of potential residual vectors. |
