poILayerFilter GetDescription
Gets the description of the layer filter.
poILayerFilter_handle GetDescription
HyperView Tcl Query
This command returns the description of the layer filter.
 create the layer filter, get the handle for the filter, and then get the description of
        the layer
        filter:
    hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle CreateLayerFilter 1 "Composite Stress" 2
result_handle GetLayerFilterHandle filter_handle 1
filter_handle SetDescription "Layer filter created from comp stress"
set description [filter_handle GetDescription]
hwi CloseStackErrors
Returns an error if the layer filter controller handle is invalid.
