poILayerFilter SetDescription
Sets the description for the layer filter.
poILayerFilter_handle SetDescription description
HyperView Tcl Modify
This command sets the description for the layer filter.
- description
- The description for the layer filter.
To create the layer filter, get the handle for the filter, and then set the description for
        the layer
        filter:
    hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle CreateLayerFilter 1 "Composite Stress" 2
result_handle GetLayerFilterHandle filter_handle 1
filter_handle SetDescription "Plies with 45 deg ply angle"
hwi CloseStackErrors
Returns an error if the layer filter controller handle is invalid.
