poILayerFilter GetID
Gets the ID of the layer filter.
poILayerFilter_handle GetID
HyperView Tcl Query
This command returns the ID of the layer filter.
To create the layer filter, get the handle for the filter, and then get the ID of the layer
        filter:
    hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle CreateLayerFilter 1 "Composite Stress" 2
result_handle GetLayerFilterHandle filter_handle 1
set id [filter_handle GetID]
hwi CloseStackErrors
Returns an error if the layer filter controller handle is invalid.
