Apply Velocities
Create concentrated velocities by applying a load, representing velocities, to a node or set.
Velocities are load config 8 and are displayed as a vector with the letter V at the tail end.
注: In the Radioss, Abaqus, and LS-DYNA profiles,
load entities are created immediately upon entering the tool. Use the エンティティエディター to modify any properties. In all other solver
profiles, load entities aren't created until you make your selections then click
Create.
From the Analyze ribbon, click the Velocities
tool.
図 1.
注: In the Abaqus profile, first click the Body Forces tool then select Velocities from the secondary ribbon. -
Select the keyword to create from the Load Type menu.
The available types depend on the current solver interface.
- Choose the entities to which the velocity will be applied
- Define the velocity's direction relative to a local coordinate system or the default global system.
Specify the magnitude and direction of the velocity.
- Constant Components
- Specify the direction and magnitude of the load by entering the X, Y, and Z values of the components.
- Constant Vector
- Specify the magnitude, then use the plane and vector tool to specify the vector along which the load should act.
- Curve Components
- Specify the X, Y, and Z components to define the direction and magnitude, for example, (2,2,2) will be twice the magnitude of (1,1,1). Next, select an existing curve. Last, specify a factor for the curve’s xscale to use the same curve for many different cases, but vary the scale of its intensity or time to match the needs of your current load.
- Curve Vector
- When working with loads that are time dependent, use this method to first specify a magnitude (yscale) for the curve. Next, select an existing curve, then use the plane and vector tool to specify a direction, if necessary. Last, specify a factor for the curve's xscale to use the same curve for many different cases, but vary the scale of its intensity or time to match the needs of your current moment.
- If working in a controller, click Create.
