Add an Altair Bushing Model
You can add an Altair Bushing Model, also known as AutoBushFD, a frequency-dependent bushing, to your MotionView model using the Add Auto Entity tool in MotionView.
Add a Bushing Model for the First Time
To add a frequency-dependent bushing to your model, you must first load the MBD-Vehicle Dynamic Tools preference file.
Select .
The Preferences window opens.
- From the list of Registered Preferences, select MBD-Vehicle Dynamic Tools, and then click Load. Loading this preference file registers a set of auto entities inside of MotionView, including AutoBushFD.
Add a Bushing to Your Model
The following steps show you how to add AutoBushFD to your model.
From the MotionView browser, right-click a model,
system or assembly, and then select Add Auto
Entity.
The Add Auto Entity window opens.
From the Add Entity dialog, do the following:
- Open the Type drop down menu and select the frequency-dependent bushing AutoBushFD.
- Also for Type, select the number for the bushing as Single or Pair (symmetric).
- Locate the Label field, and enter a label string for your bushing.
- Locate the Variable field, and enter a variable name for your bushing.
- Click OK or 適用 to add the bushing to your project.
The bushing is added and appears in your MotionView browser.
