PARAM, AMLSMEM
Bulk Data Entry Defines the amount of memory in Gigabytes to be used by the external AMLS eigenvalue solver.
| Parameter | Values | Description |
| AMLSMEM | <Real> Default = Memory used by OptiStruct for a particular run. |
This parameter is used to
define the amount of memory in Gigabytes to be used by the external
AMLS eigenvalue solver. This parameter is
only valid for AMLS versions 5 and
higher. Refer to AMLS (Automatic Multi-level Sub-structuring) Eigensolver in the User Guide for more details. |
- If this parameter is not set, AMLS will use the amount of memory that OptiStruct is using for the run.
- OptiStruct and AMLS can be run with different allocations of memory. For example, OptiStruct can be run with 10.0 Gigabytes and AMLS with 20.0 Gigabytes in the same run.
- If the environment variable
AMLS_MEMis set, it will override the value set using PARAM,AMLSMEM. - This parameter can be used only if PARAM, AMLS is set to YES.
- The minimum AMLSMEM memory value allowed is equal to 1 GB. If a value lower than 1 GB is specified, it is automatically reset to 1 GB.
