PARAM, PSDPRINC
Bulk Data Entry This parameter controls the output of PSD/RMS Absolute Maximum Principal Stress and PSD/RMS Absolute Maximum Principal Strain for Random Response Analysis.
| Parameter | Values | Description |
| PSDPRINC | <YES,
NO> Defaults: When the parameter is not present in the deck, then Maximum principal stress/strain is not calculated or output. When the parameter is present in the deck, but no option/value is provided, then the Absolute Maximum Principal stress/strain is calculated and output. |
