Bulk Data Entry The optimization process involving nonlinear
analysis, in the subsequent optimization iteration the solution of the nonlinear
problem.
| Parameter |
Values |
Description |
| NLINISOL |
<YES,
NO> |
- YES (Default)
- The optimization process involving nonlinear analysis,
the nonlinear problem will start, when feasible, from
the converged nonlinear solution of the previous
optimization iteration (instead of repeating the entire
incremental nonlinear process). This can save
computational time.
- NO
- The optimization process involving nonlinear solutions,
nonlinear analysis is always repeated from the
beginning. The entire incremental nonlinear process is
conducted for the analysis.
- This re-using of the previous converged solution is only supported when
the nonlinear solution is not path-dependent.
