PARAM, AUTOMSET
Bulk Data Entry Automatically convert dependent degrees-of-freedom of rigid elements to independent degrees-of-freedom.
| Parameter | Values | Description |
| AUTOMSET | <YES,
NO> Defaults:
- This parameter can be used if the dependent degree-of-freedom (DOF) of a rigid element is SPC'ed, or if it is a dependent DOF of another constraint equation (MPC equation or another rigid element).
- AUTOMSET cannot be used if Direct Matrix Input (DMIG) generation is performed using the Static Condensation method (Component Mode Synthesis (CMSMETH entry) is not used).
- Enough independent degrees-of-freedom that can be converted into dependent degrees-of-freedom, while eliminating double dependency, should exist in the model
- PARAM, AUTOMSET is set automatically to YES even in the presence of JOINTG elements. However, the constraints from JOINTG elements will not be modified.
