PARAM, HASHASSM
Bulk Data Entry Enables hash-table based assembly.
| Parameter | Values | Description |
| HASHASSM | <YES, NO> | The hash-table based
assembly method reduces the memory requirement of the assembly
module by about a factor of 3 for linear static analyses, by about a
factor of 5 for eigenvalue analyses, and by about a factor of 7 for
frequency response analyses involving material damping. The reduction in the overall memory requirement is problem-dependent. For problems where modules other than the assembly module are dictating the overall memory requirement, using this alternative assembly method will not result in a reduction in the overall memory requirement. Using the hash-table based assembly method while possibly reducing memory requirements may result in longer run times.
- Some examples of when the
hash-table assembly method is automatically activated are:
- STATSUB (BUCKLING/PRELOAD/BRAKE) points to a large displacement nonlinear subcase.
- Large displacement nonlinear analysis involves finite sliding contact.
- Large displacement nonlinear analysis with DDM.
