PARAM, LCLGRDST
Bulk Data Entry This parameter can be defined in the local model of a submodeling job, to output the mapping information of each local node to the global nodes, for all the local nodes in a set.
| Parameter | Values | Description |
| LCLGRDST | <GRID_SETID> |
No default |
- The mapping information is printed to a .mapdsp file and only when this parameter is defined.
- For more information, refer to Global-Local Analysis (Submodeling) in the User Guide.
