- Positive Integer
- References the SET identification
number of an element set that is included in the element
quality check. All other elements in the model, except
for the specified SET ID, are excluded from element
quality testing (see checks 2 and 3 in the Element Quality Check). Element validity
checks (check 1) are always conducted regardless of the
value of CHKELSET.
- Negative Integer
number of an element set that is excluded from the
element quality check. All other elements in the model,
except for the specified SET ID, are included in the
element quality testing. Element validity checks (check
1) are always conducted regardless of the value of
CHKELSET.
PARAM, CHECKEL,
YES is ignored when
PARAM, CHKELSET is
specified.
The ELEMQUAL Bulk Data
Entry may be used to control the values for warning and error
limits for each quality check, but validity limits cannot be
altered by manually.
