PARAM, GE4FRSTF
Bulk Data Entry Controls the contribution of material damping, in addition to the stiffness contribution in the element force calculation for frequency response analysis.
Parameter | Values | Description |
GE4FRSTF | <0, 1> |
- By default, the material damping contribution is always included for CBUSH elements.
- The value of damping will be considered from the Material/Property/NSGE or PARAM, G entries in the model.
- The element forces of viscous damping elements CDAMP1, CDAMP2, CVISC elements and viscous contribution in CBUSH elements are calculated and provided as output (upon request), independent of this parameter.
