PARAM, GE4TRSTF
Bulk Data Entry Controls the contribution from damping, in addition to the stiffness contribution in the element force calculation for Linear Transient Analysis.
| Parameter | Values | Description |
| GE4TRSTF | <0, 1> |
- The value of damping will be considered from the Material/Property/NSGE or PARAM, G entries in the model.
- When PARAM, GE4TRSTF, 1 is used, the element forces for CDAMP1, CDAMP2, CVISC elements and viscous contribution in CBUSH elements are calculated and provided as output, in case of Linear Transient Analysis.
