PARAM, CHECKMAT
Bulk Data Entry Activates material property checking.
| Parameter | Values | Description |
| CHECKMAT | <YES,
NO, FULL> Defaults = See Comments |
- When this parameter is not specified in the input file, the default is equivalent to PARAM,CHECKMAT,YES.
- When this parameter is present in the input file without any argument (PARAM,CHECKMAT), the default is equivalent to YES,
