PARAM, LOWRANK
Bulk Data Entry This parameter is obsolete. Use PARAM,K4METH to control the value of LOWRANK.
| Parameter | Values | Description |
| LOWRANK | <0, -1> | This parameter is
LOWRANK. PARAM,
LOWRANK relates to the faster Modal
Frequency Response solution method invoked by PARAM,
FASTFR and the FastFRS solution invoked by PARAM,
FFRS. LOWRANK is used to select
the solution strategy used to handle the modal structural
damping matrix.
