PARAM, FIXRBE3
Bulk Data Entry Used to automatically fix invalid RBE3’s.
| Parameter | Values | Description |
| FIXRBE3 | <YES, NO> | Used to automatically fix
invalid RBE3's, which typically exhibit the following
characteristics.
- For PARAM,FIXRBE3,YES, the fixed RBE3’s are printed in the .out file. Check these RBE3’s and make sure that the model behavior is not unexpected.
