PARAM, RFIOUT
Bulk Data Entry Controls the output of modal super element for use in the RecurDyn multibody dynamics software from FunctionBay.
| Parameter | Values | Description |
| RFIOUT | <YES, NO> | This information is
written to the .rfi file. This should be used
with CMSMETH
CBN and ASET
DOF for the connection points.
- This .rfi file can be created only by OptiStruct executables running on 64-bit Windows machines. This file cannot be created while using OptiStruct on Linux or Mac OS X machines.
