PARAM, TPS
Bulk Data Entry Activates fast transient response analysis (only shell stress results output).
| Parameter | Values | Description |
| TPS | <YES, NO> | PARAM,
TPS may be used with transient response
analysis. When only shell stress results are required from a
transient response analysis, significant speed improvements in run
time can be obtained with the use of this parameter.
