PARAM, CRTELEM
Bulk Data Entry Controls the printing of the “n” smallest element/nodal timesteps for Nonlinear Explicit Analysis.
| Parameter | Values | Description |
| CRTELEM | <Integer> Default = 10 |
This parameter is used
to control the printing of the “n” smallest element/nodal
The following is printed to the .out file for a model when
PARAM,CRTELEM,20
is:
20 smallest element/nodal timesteps
Type ID Timestep
Solid 1092 5.2667E-04
Solid 1156 5.2667E-04
Solid 1036 5.2667E-04
Solid 1085 5.2667E-04
Solid 1100 5.2667E-04
Solid 1149 5.2667E-04
Solid 1029 5.2667E-04
Solid 1093 5.2667E-04
Solid 964 5.3370E-04
Solid 1028 5.3370E-04
Solid 908 5.3371E-04
Solid 972 5.3371E-04
Solid 1284 5.3371E-04
Solid 1220 5.3371E-04
Solid 1228 5.3371E-04
Solid 1164 5.3371E-04
Solid 1021 5.3371E-04
Solid 957 5.3371E-04
Solid 965 5.3371E-04
Solid 901 5.3371E-04
