*CE_AddLinkEntities
Update connectors with entities.
*CE_AddLinkEntities connector_mark_id entity_type entity_mark_id
HyperMesh Tcl Modify Command
This command updates connectors with entities.
- connector_mark_id
- The ID of the mark containing the connectors to update. Valid values are 1 and 2.
- entity_type
- Type of entity to be added to the connectors as links.
- entity_mark_id
- The ID of the mark containing the entities to use as links. Valid values are 1 and 2.
Examples
To add comps 1 and 2 as to connectors
1-3:
*createmark connectors 1 1-3
*createmark comps 1 1 2
*CE_AddLinkEntities 1 comps 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
