*metadatamarkintarray
Creates integer array metadata on the specified mark of entities.
*metadatamarkintarray entity_type mark_id name integer_array number_of_integers
HyperMesh Tcl Modify Command
- entity_type
 - The type of entities contained on the mark.
 - mark_id
 - The ID of the mark containing the entities to which the metadata will be added. Valid values are 1 and 2.
 - name
 - The name by which the metadata will be referenced.
 - integer_array
 - The ID of the integer array that contains the values. The array is created using the *createarray command. This should always be set to 1.
 - number_of_integers
 - Integer indicating the size (number of integers) in the array created using *createarray.
To add metadata named Int_Vals with the values 5 and 7 to elements
        1-100:
    *createmark elems 1 1-100
*createarray 2 5 7
*metadatamarkintarray elems 1 "Int_Vals" 1 2Errors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
