*CE_InputSigPoints
Imprints nodes or points as significant points on connectors.
*CE_InputSigPoints <select_type>=<selection> connector_mark=<mark_id> tolerance=<value>
HyperMesh Tcl Modify Command
- <select_type>=<selection>
- There are several ways to provide the ID of the mark containing the entities to be
            imprinted as significant points on connectors. Valid values are 1 and 2. Only one option
            can be used at a time:- node_mark=<mark_id>
- The ID of the mark containing the nodes to be imprinted.
- point_mark=<mark_id>
- The ID of the mark containing the points to be imprinted.
- connector_mark=<mark_id>
- The ID of the mark containing the connectors on which to add the significant points.
- tolerance=<value>
- The tolerance value defining the maximum distance between the nodes/points and the selected connectors.
Examples
To imprint points ID 1-10 as significant points on connector ID 1 using a tolerance
        100:
    *createmark points 1 1-10
*createmark connectors 2 1
*CE_InputSigPoints point_mark=1 connector_mark=2 tolerance=100Errors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
2022.3
