*analysisfileset
Loads a results file for use in subsequent operations.
*analysisfileset filename
HyperMesh Tcl Modify Command
Loads a results file for use in subsequent operations. All IDs are assumed to be HyperMesh internal IDs.
- filename
- The full path and name of the results file.
Examples
To load the result file named C:/my_results/test.res:
*analysisfileset C:/my_results/test.resErrors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
