*morphmapedgestoplaneoffset
Maps selected morph volume edges to the specified plane.
*morphmapedgestoplaneoffset user_mark_id plane_id use_symmetry use_constraints project vector_id number_of_mid_handles offset
HyperMesh Tcl Modify Command
This command will project the handles on the marked morph volume edges to the specified plane along the specified vector, plane normal, or normal to any attached shell elements (unusual for morph volume edges).
- user_mark_id
- The ID of the user mark containing the morph edges. Valid values are 0-3.
- plane_id
- The ID of the plane created using *createplane. Valid values are 1 and 2.
- use_symmetry
- 0 - Do not use symmetry links
- use_constraints
- 0 - Do not use constraints
- project
- 0 or 10 - Project along vector defined by vector_id
- vector_id
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- number_of_mid_handles
- -1 - Do not change the handles on the edges
- offset
- The distance to offset nodes from the target.
Examples
To map edges on mark 0 to a plane along a vector with offset of 1.2 and leaving the handles unchanged:
*morphmanageedgemark 0 0 3
*morphmanageedgemark 2 0 1
*morphmanageedgemark 4 0 1
*createplane 1 1.0 0.0 0.0 1.0 0.0 0.0
*createvector 1 1.0 0.0 0.0
*morphmapedgestoplaneoffset 0 1 1 1 0 1 -1 1.2
*morphmanageedgemark 0 0 3To map edges on mark 1 to a plane along the plane normal with 3 mid-handles per edge:
*morphmanageedgemark 0 1 3
*morphmanageedgemark 2 1 1
*morphmanageedgemark 4 1 1
*createplane 1,1.0 0.0 0.0 1.0 0.0 0.0
*morphmapedgestoplaneoffset 1 1 1 1 1 1 3 0.0
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
14.0.110
