*collisionsetoutdated
Sets collisions referred by selected components to outdated.
*collisionsetoutdated outdatedcompids=<value>
HyperMesh Tcl Modify Command
This command finds collisions referring to specified components and sets them as outdated.
- outdatedcompids={id1 id2 … idN}
- The list of component IDs.
Examples
To set collision entities involving components with IDs 1 or 2
outdated:
*collisionsetoutdated outdatedcompids={1 2}Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2024
