*CE_ConnectorRemoveDuplicates
Deletes connectors that are considered to be duplicates of other connectors within a given tolerance.
*CE_ConnectorRemoveDuplicates markMask tolerance
HyperMesh Tcl Modify Command
- markMask
- The mark mask (1 or 2).
- tolerance
- The maximum distance between two connectors that are considered to be duplicates.
Examples
To delete duplicate connectors on the mark mask 1 within 0.05
        tolerance:
      *CE_ConnectorRemoveDuplicates(1, 0.05)Currently only supported for connectors located at geometric points.
