*create_shell_mesh_features
Generates plot elements between 2D elements.
*create_shell_mesh_features entity_type mark_id feature_angle reserved
HyperMesh Tcl Modify Command
Generates plot elements between 2D elements whose normals exceed the a specific angle. Connects features to the boundary or to other features, trying to create convex areas. All features generated are placed into a component named ^feature.
Connected features are created by default for interactive and automatic elements remesh.
- entity_type
- Entity type containing the 2D elements. Valid values are:
- comps
- elems
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- feature_angle
- The maximum angle allowed between any two plate elements before a plot element is generated between the shared sides of the two elements.
- reserved
- Reserved for future use. Must be set to 0.
Examples
To create connected lines representing features on the component named "hood" based on a
30.0 degree feature
angle:
*createmark components 1 hood
*create_shell_mesh_features component 1 30.0 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
