*applyscenario
Applies control and realizes the entity for a given scenario.
*applyscenario scenario_name=<value> entity_type=<value> overwrite_attrib=<value> realize=<value>
HyperMesh Tcl Modify Command
Applies control and optionally realizes it. This works on any given supported entity type or on all the supported entities. Once the entity is filtered and the control is applied, same entity is ignored from next definitions.
- scenario_name=<value>
- The name of the scenario to apply.
- entity_type=<value>
- The entity type the scenario will be applied to. Valid values are connectors, attachments, and all.
- overwrite_attrib=<value>
- The flag defining the behavior related to any delta values on the engineering entity.
- realize=<value>
- The option to realize the entities after applying the control.
Examples
To apply control for connectors and realize them by overwriting local values from controls
in scenario name
Crash:
*applyscenario scenario_name=Crash entity_type=connectors overwrite_attrib=1 realize=1To apply control for all the supported entities and realize them by keeping existing value
of overwriting attribute flag in scenario name
NVH:
*applyscenario scenario_name=NVH entity_type=all overwrite_attrib=3 realize=1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.2
