*addposition
Adds a solver position into another solver position entity.
*addposition mark_id1 mark_id2
HyperMesh Tcl Modify Command
Adds a solver position into another solver position entity. Currently only supported to add positions with config 407 into positions with config 408 in PAM-CRASH Interface. Alternatively, *setvalue can be used.
- mark_id1
- The ID of the mark containing the position entities to which the positions in mark_id2 must be added to.
- mark_id2
- The ID of the mark containing the positions entities to be added.
Examples
To add all the positions with config 407 to all the positions with config 408:
*createmark positions 1 "by config" "407"
*createmark positions 2 "by config" "408"
*addposition 2 1
Incorrect usage results in a Tcl error. To detect errors, you can use the catch
        command:
   # Handle error
Version History
2021.1
