*masknotshown2
Masks all supported entities not in the current view window.
*masknotshown2
HyperMesh Tcl Modify Command
Masks all supported entities not in the current view window. Only entities in displayed
collectors are affected. This includes:
- points
- lines
- surfaces
- solids
- elements (both in components and groups)
- connectors
- ellipsoids
- mbjoints
- mbplanes
- loads
- equations
- systems
- vectors
To mask all supported entities in the displayed collectors that are not in the current view window:
*masknotshown2
None.
Version History
14.0
