*remesh_optistruct
Remeshes the current model with FE type definitions maintained, used to improve the mesh quality in OptiStruct free shape, shape or topography optimization.
*remesh_optistruct string_array number_of_strings
HyperMesh Tcl Modify Command
Remeshes 2D elements at intersection locations. Only elements belonging to different components are taken as counterparts for the intersection calculation. Moreover, elements sharing a node are not counterparts for the intersection calculation.
- string_array
 - The ID of the string array that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
To executes the function on the current model, taking the optimized grid coordinates from
        the file C:/test/torquearm.grid, and performing remeshing with grids in
        SET number 2 fixed:
    *createstringarray 2 "fgrd: C:/test/ torquearm.grid"
*remesh_optistruct 1 2Errors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
12.0.110
2023 - Removed the options skipgs and skiges.
