*modelcheck_runchecks
Runs model checker checks.
*modelcheck_runchecks ?check_display_name? ?entity_type? ?error_type? ?mark_id?
HyperMesh Tcl Modify Command
If executed with no arguments, then all checks for all entity types in the profile are run.
- check_display_name
- The GUI display name of the check. This is case sensitive.
- entity_type
- The type of entity to be checked.
- error_type
- The type of errors to check, ERROR, WARNING, INFO or ALL.
- mark_id
- The ID of the mark of entities for which model checker is to be run. Valid values are 1 and 2.
Examples
Run the check named "checkname":
*modelcheck_runchecks checknameRun all checks on properties 1-10 :
*createmark props 1 1-10
*modelcheck_runchecks "" props "" 1Errors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
2019
2023 - Added new value “DISPLAYED” for entity_type.
