*unmaskentitiesincollector
Unmasks the specified entities contained within the specified collectors.
*unmaskentitiesincollector entity_type mark_id flag_1 flag_2 flag_3 flag_4 flag_5 flag_6
HyperMesh Tcl Modify Command
This command unmasks the entities contained within the collectors of entity_type that are on mark_id. Valid mark_ids are 1 and 2. Only entities in displayed collectors may be unmasked.
The six flag arguments indicate the type of entities to unmask within the specified collectors. If the flag is set to 1, that entity is unmasked. If the flag is set to 0, that entity is not modified. Currently supported entity_types and flags are:
- comps
- flag_1 - elements
- groups
- flag_1 - main elements
- loadcols
- flag_1- loads
- multibodies
- flag_1 - ellipsoids
Examples
To unmask all of the points and surfaces in the displayed
components:
*createmark components 1 displayed
*unmaskentitiesincollector comps 1 0 1 0 1 0 0 To unmask all ellipsoids and mbjoints in all
multibodies:
*createmark multibodies 2 all
*unmaskentitiesincollector multibodies 2 1 1 0 0 0 0Errors
Incorrect usage of *unmaskentitiesincollector results in a Tcl error. To detect errors, you can use the catch
command:
if { [ catch {*unmaskentitiesincollector comps 3 1 1 1 1 1 1} ] } {
# Handle error
}Version History
9.0
